First working module prototype
A project log for Low Cost Home Automation
A home automation solution that utilizes a Raspberry Pi server, 433MHz radios, and an Android app.
daniel-hankewyczDaniel Hankewycz • 08/21/2014 at 02:00•0 Comments
(07/21) Successfully built and tested a working relay based outlet module. This module uses a HC05 bluetooth module to communicate to the central hub.
