Well I took another look at the MPLAB Code Configurator for the firmware and I realized I was only running the CPU core at something like 8MHz. So I modified the multiplier so it's running at 48MHz and the improvement was significant. Flash program and verify now takes 35 seconds and @Xark reports SRAM programming takes only 2 seconds. Very nice! This is before any bulk serial optimizations have been added. I'm very happy with this result.
Next steps: I want to add the bulk serial optimizations in and see even better performance. Then I will add support for programming .jed and .bit files directly, and finally I will add the module into the TinyFPGA Programmer GUI that exists for #TinyFPGA B-Series.
Once that is done and working to my satisfaction I'll be making some more revisions to the PCB. I think it makes sense to breakout all the PIC's pins so that the board can be used for other purposes as well. So I can add support for UART and SPI along with it's existing GPIO capabilities. That will make it a dirt cheap programmer that can be used for many things.
