I have pushed an update to the TinyFPGA B-Series GitHub repository with a template for the open source icestormFPGA synthesis flow. Take a look at the new README for detailed instructions.
I've also added support for programming TinyFPGA B-series bitstreams using a command-line interface. Take a look at the READ for instructions on using the command line interface.
