Exploration and Experiment
A project log for Visioneer
AI glasses that provide traffic information and obstacle avoidance for the visually impaired.
makervisioneerMakerVisioneer 08/16/2017 at 18:200 Comments
We’ve explored the recognition capabilities of Google Vision and OpenCV. We decided to go with OpenCV, for our phase one design, because of its movement detection capability.  Google Vision remains an option for recognition, but we intend to try local neural nets first to eliminate the dependency on an outside service.
Recognizing the label with Google Vision when it is less than 20 cm.
Using OpenCV to detect motion, speed, and position with a selected area on a frame.
Google cloud vision's activation by detecting an object with more detailed info within 30cm by an Ultrasonic Sensor
Google Vision and Speech API via Asus TinkerBoard
Motion tracking with OpenCV
We also did an experiment to determine how many cameras should be used, as well as, which angle is best for traffic detection. The conclusion was that two cameras in the angle of 60 degrees are best for performing traffic detection.
1. One camera, forward facing, no deflection.
2. Two cameras, forward facing, no deflection
3.  Two cameras, 15 degree deflection
4.  Two cameras, 30 degree deflection
5.  Two cameras, 45 degree deflection
6. Two cameras, 60 degree deflection
7. Two cameras, 90 degree deflection (side facing)
