corrected the grove connector
![](https://cdn.hackaday.io/images/8058771506528278688.png)
also, for programming and prototyping:
![](https://cdn.hackaday.io/images/8485161506528278635.png)
A project log for I2C peripherals based on Attiny85 (mostly)
making noise over I2C, or send IR remotes or get an external controller, just stuff that is only helping if you don't have spare pins left
nice!
I see you are practicing for the 1cm² contest!
that's more like square inch stuff though
still good practice
yeah, after all, standard is WAY better than the metric system
@ActualDragon you mean the imperial system? the standard in 2 out of 150+ countries of the world?
phhhtt yeah, the two best countries, whats the second one?
no clue, don't care :) inches are fine by me as well, other stuff is weirder.
yeah, dosent really matter to me either- shop is imperial, metric is chem
