Boards are here and although they have some mouse bites, they do fit nicely :) Already soldered one up and it works nicely! Now I only need to write an 8 player game to fully make use of them :D
![](https://cdn.hackaday.io/images/9200071510695985468.png)
A project log for I2C peripherals based on Attiny85 (mostly)
making noise over I2C, or send IR remotes or get an external controller, just stuff that is only helping if you don't have spare pins left
Are you picking up the membrane keypads on AliExpress or something>
That's a good idea, never thought of doing that
For now I have a little stock of used buttons and pads but since there are so many replacement pads and buttons on aliexpress... I thought why not :) A bit inspiration to actually do it came from the mintipi project, they use nintendo ds buttons, but I had the idea / need for a while.
Is that a negative mousebite?
oh wow, seems like it
