This protection device will keep you safe by just pressing a button. If you are in Danger, just press the button and your location will be shared on any website you select in code. By the use of Infineon DPS310 pressure sensor, height of person in building can also be detected for precise location. The Device will run on 9v Battery. It is handy device. You can make enclosure and keep the circuit in it.
mircemk
DIGI
Jean-Matthieu DECHRISTÉ
Enderby
