I haven't done any work on this because I'm stuck looking for a suitable vacuum pump that doesn't cost an arm and a leg.
The vacuum level isn't that high, but most chinesium-grade pumps I've seen don't look that promising.
I may have found one that fits the bill, both in price and performance. It's a second hand, 2 stage pump. Hope it also works. Sometime next week I'll find out if this is really the case or I just threw away 50 Euros.
I've also been thinking about the set-up and fittings I'm going to use. I basically want a set-up that's easy to disassemble and also holds a vacuum. Kind of much for them, but I'll test this out once I have the pump (if it works)
