Tonight I assembled the first article of the LoFive.
Here are a few pictures of the process.
Pre-oven component placement:
Fresh out of the oven:
Few pictures of the de-panelized board:
Comparison to the Teensy (~same form factor):
Picture of the 16Mhz crystal jamming and power supply current:
Next up JTAG and software tests.
Hmmmm .. now how do I put the bootloader on there...
Cool. Do you have a set temperature profile that you use in the oven? Could you share?
I was using leaded solder paste and the standard lead reflow setting on the reflowster.
http://reflowster.com/
Can't wait to see a blinking led!
I might have a tricolor LED that I can hook up.
Awesome!
