The print turned out well this time.
The virtual pulley edges with an extended horizontal surface are now clean so the lines should move nicely. It's also stiffer than the last one.
The lines are run down through one hole, across the bottom, and up through the other hole. This made leveling the print head super easy, but it also means I need to cut my lines to put the new one in.
