Finished all the cuts I needed to make in the MDF base.
Instead of trying to cut the granite tile, I've recessed it into the back of the MDF. This reduced my build area a little, but it's still 300mm so I'm happy enough with that.
Gave it a couple coats of primer and then some hammered paint. MDF really soaks up paint.
Assembled the end effector.
I didn't use the groove mount. I just threaded the push fitting through the inside of the end effector and screwed it on.
And I installed and wired up the homing switches.
Once the extruder mount is done printing, I'll finally be ready to assemble this thing.
