Weebles wobble
A project log for Arcus-3D-C1 - Cable 3D printer
3D printable, Open Source Hardware, tripod kinematics, cable driven 3D printer
masterofnullMasterOfNull 09/21/2018 at 00:060 Comments
Noticed that at the edges of the build area, I was getting some offset from planar on the end effector, not related to the virtual pulleys.  The difference in tension between the near and far lines looked to be bending the top corner brackets.  On closer inspection, they weren't bending, but instead just wobbling where they slid onto the rods.
To allow them to be removable, I needed them to be a little looser than a press fit, or you end up breaking them when you take it back apart.
So I've updated the top corners to add some more depth (18mm is now 24mm) to the pockets the support rods go into, and added the bit I've applied to other parts of adding flat spots to the inside of shaft pockets to allow for a tight, but slip fit over a greater range of error in either the rod diameter or the extrusion.
The driveway markers I have vary in diameter over a range of about 0.2mm, which is a huge 2.5% variance given their nominal OD of 7.9mm.
Reprinted.
Adding the flats seems to have done the trick.
Assembling using the updated parts now.
Rich text editor
