Paint.
A project log for Arcus-3D-C1 - Cable 3D printer
3D printable, Open Source Hardware, tripod kinematics, cable driven 3D printer
masterofnullMasterOfNull 10/20/2017 at 06:410 Comments
Finished all the cuts I needed to make in the MDF base.
Instead of trying to cut the granite tile, I've recessed it into the back of the MDF.  This reduced my build area a little, but it's still 300mm so I'm happy enough with that.
Gave it a couple coats of primer and then some hammered paint.  MDF really soaks up paint.
Assembled the end effector.
I didn't use the groove mount.  I just threaded the push fitting through the inside of the end effector and screwed it on.
And I installed and wired up the homing switches.
Once the extruder mount is done printing, I'll finally be ready to assemble this thing.
