Came up with my best guess as to how to generate the settings I used in the INI file from the physical machine and documented them. Software source updated in the Github repo.
The settings are inter-dependent due to the tripod kinematics.
A group of settings that results in a flat coordinated move at the bed won't be flat at Z+100 if I don't have them all right. If it's not flat everywhere, then scale will be off as well.
So, I still need to mount the bed and be able to fine tune the leveling it so I can take good measurements at multiple points and at least two heights to check my math.
Tomorrow.
