Extruder v3, nope. Extruder v4.
A project log for Arcus-3D-C1 - Cable 3D printer
3D printable, Open Source Hardware, tripod kinematics, cable driven 3D printer
masterofnullMasterOfNull 11/19/2017 at 22:450 Comments
I've dropped moving the hotend inside the end effector for now.
Raising the pushrod joint to the top of the heatsink didn't work.  No down-force on the inside edge when near the edge of the build area..  It has a new github branch if anyone wants to play around with it.
I was able to reduce the offset by about 1/3rd by moving it up so the hotend flange is up inside the U joint instead of being surface mounted on the bottom.
That was relatively easy.  Added my part cooling fan mount while I was at it.
Printing the new parts.
