Snag-o-rama
A project log for Raspberry Pi Temperature Sensor Network
The Raspberry Pi will be a server for various NodeMCU ESP8266 "nodes" which will each host a temperature sensor
quintin-balsdonQuintin Balsdon • 09/03/2017 at 17:09•1 Comment
I have updated the code on the repo, but unfortunately there is a slight problem: You cannot start or flash the NodeMCU chip when there is a connection to the 3v3 pin. This means I am going to need to add a switch to my PCB design. I'll update it when all the components come in from eBay.
Quintin Balsdon wrote 09/06/2017 at 13:13 • point
Please see the next post - I was wrong!
