I have updated the code on the repo, but unfortunately there is a slight problem: You cannot start or flash the NodeMCU chip when there is a connection to the 3v3 pin. This means I am going to need to add a switch to my PCB design. I'll update it when all the components come in from eBay.
Quintin Balsdon
Please see the next post - I was wrong!
