Moving forward!
A project log for Raspberry Pi Temperature Sensor Network
The Raspberry Pi will be a server for various NodeMCU ESP8266 "nodes" which will each host a temperature sensor
quintin-balsdonQuintin Balsdon • 09/08/2017 at 08:55•0 Comments
So I have updated the web page so that the report looks much better! Mouse hovers over time were causing some weird memory issues.
One thing I did realise with deploying to the Node from another computer: You will need to install the OneWire library in Arduino (Sketch -> Include Library -> Manage Libraries):
I am hoping to call the Pi server "stable" at some point. Currently I was having wifi issues and I think that was terminating the SSH session and then the server would stop. So now I SSH over a hard LAN cable (I am using a Pi 3 for now)
