About addressable led APA102C
have double line transfer, very powerful.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
1. Product Overview :
SK9822 is a two-wire transmission channel three (RGB) driving intelligent control circuit and the light emitting circuit in one of the LED light source control. Products containing a signal decoding module, data buffer, a built -in constant current circuit and RC oscillator; CMOS, low voltage, low power consumption; 256 level grayscale PWM adjustment and 32 brightness adjustment; use the double output, Data and synchronization of the CLK signal, connected in series each wafer output action synchronization.
2. Main Application Field:
●Full color LED string light, LED full color module, LED super hard and soft lights, LED guardrail tube, LED appearance / scene lighting
●LED point light, LED pixel screen, LED shaped screen, a variety of electronic products, electrical equipment etc..
3.Description:
●Top SMD internal integrated high quality external control line serial cascade constant current IC; 5V application; default on elect
