Winner concept: A transfer board that allows one side to be elevated while the person is seated.
Other ideas:
- Hoyer
- Pump-able
- Automatic
- Pushes a button and automatically transfers
- Board with wheels
- Start sliding once you’re on
- A conveyor belt
- Platform for chair to become higher than the bed
- Something to lower the bed
- Air inflator in seat that deflates on one end so the patient slides
- Like a wedge
- A wheelchair that flattens to the height of bed
- The patient does a roll
- Wheelchair is part of the bed
- Hoyer lift with magnet
- A vest that assists with lifting oneself
- Like the pull up machine with weights
- Using the momentum to fall on top of the bed
- Using mini-steps to go backwards on to the bed
- A wheelchair where you can take off the back so that you can go backwards
- Go backwards
- Escalator to the bed
- A conveyor belt that will let you slide into your chair
- Monkey bar to move yourself into the bed
- Something hanging that they can grab on to
- Maybe there’s a counter weight
- Make the bed into a jungle gym
- Put a little bit of C4 under the butt and poof
- Similar to spring loaded trampolines
- Electromagnet maglev to slide the patient
- Or air pressure
- Use long stick
- The wheelchair seat that attaches to a pole and the seat moves
- Cushion that elevates from the chair
- An arm to turn onto the chair
- Back to the bed and chair pushes up
- Air mattress cushion that will lift them
- A wench that will pulls you up to the bed
- Like a zip line that will lift them up
- A slide in the seat that slides in and out like Chinese table
Riya Fukui
