Terrible cell phone pic, the 1.3" 128x96 OLED SSD1306 is a direct drop in replacement for the 0.96".
Though it is $5.00 vs $2.57 , I do like the bigger display . I'll hopefully take a better pic of it, certainly couldn't take a worse one. It still has the plastic cover on it.
Compared to the 0.96"
These are remarkably easy to solder and desolder, lay a small line of paste over the pads and drag solder, then run the iron parallel to the edge connectors for each pad to clear up any bridges or excess solder , don't go nuts on the amount of paste.
To desolder all i did was gently lift one side at the right of the connect and slowly move the iron right to left over the pads and it just lifts off. i am using leaded solder.
charliex
