Well layerone has been and gone, and apparently it was great, i don't know since i was in the back room getting a couple of hours sleep coding, while the others around me soldered boards together. I'm usually one to write up logs as they happen or just after, but this was a serious drain ( as well as the fact i have to delveop multiple hardware systems at work by siggraph), we're still building out badges.
Did the board work ?, yes it did, I missed one mosi line to the OLED so that was a kynar fix, but beyond that so far everything has worked, we read tags.
terribly grainy video
The HF/LF add on.
