added a larger OLED
A project log for LayerOne 2014 Conference Badge
Electronic Badge, Based on the Proxmark3 with different FPGA, SAM7 , SDCARD and OLED
charliexcharliex • 03/05/2014 at 17:58•3 Comments
Terrible cell phone pic, the 1.3" 128x96 OLED SSD1306 is a direct drop in replacement for the 0.96".
Though it is $5.00 vs $2.57 , I do like the bigger display . I'll hopefully take a better pic of it, certainly couldn't take  a worse one. It still has the plastic cover on it.
Compared to the 0.96"
These are remarkably easy to solder and desolder, lay a small line of paste over the pads and drag solder, then run the iron parallel to the edge connectors for each pad to clear up any bridges or excess solder , don't go nuts on the amount of paste.
To desolder all i did was gently lift one side at the right of the connect and slowly move the iron right to left over the pads and it just lifts off. i am using leaded solder.
Ben Delarre wrote 03/05/2014 at 18:15 • point
Where did you get the 0.96" so cheap? Been looking for a tiny OLED screen for a USB stick project...
Mike Szczys wrote 03/12/2014 at 18:12 • point
That's the first thing I thought of as well. Is this in qty?
arko wrote 03/05/2014 at 18:14 • point
Woah! Might actually be readable from far away :D
