This 3D printed object is an assistive technology designed to make the asthma treatment more effective, convenient and friendly by improving the ergonomy of any standard asthma inhaler available on the market.
This simple 3D printed tool is an effective assistive solution to improve the usage of the inhaler devices by people suffering from asthma.
asthma_inhaler.stl3D model (.stl) ready for 3D printingStandard Tesselated Geometry - 1.21 MB - 08/28/2017 at 11:25 |
Just click on the following link and download the the .stl model file of the asthma inhaler:
Open the downloaded .stl model file with your favourite slicer tool (i.e. Cura, KISSlicer, Repetier, Slic3r, etc.).
The 3D printing slicer prepares the selected model for your 3D printer, generating g-code, which is a widely used numerical control programming language. There is a large number of slicing software, many of which is free. At the following link you can find a list of the top 3D printing slicer software tools:
Once you have opened the .stl model file with your slicer tool, set the 3D printer parameters as following:
There are basically 2 ways to orientate the object to achieve an optimal printing:
I've experimented both printing options and I got the best printing results implementing the rotation by 120 degrees.
Then genetare the g-code file with the slicer tool and copy it to the SD card.
