I finally got a chance to put together very first FAIO board and start writing the firmware for it to operate in Adaptive Switch mode.
In this mode the FAIO Switch will act as a basic switch interface with two 3.5mm Audio jacks that can be used to connect up to two Adaptive Switches and can be used to operate/navigate a smartphone or computer through switch control option in iOS or Android. An adaptive switch button can be connected to one of the 3.5mm Audio jacks to act as a selected switch button and another one to other 3.5mm Audio jack in order to move to the next item when it's setup as a switch.
I picked up an Adafruit Feather 32u4 Bluefruit LE board for this project.You will need to solder header pins to it before being able to use it.
![](https://cdn.hackaday.io/images/4646961506672359394.jpg)
Once the necessary components are soldered to the main board then you can go a head and stack the Adafruit Feather 32u4 Bluefruit LE board on the FAIO board.
![](https://cdn.hackaday.io/images/6011971506672481526.jpg)
The instruction manual will become available soon but until then you can see how it would lookalike.
![](https://cdn.hackaday.io/images/4901961506672694361.jpg)
Coming up: Software details and information about Sip-And-Puff mode as well as Braille mode
