Microwaves are usually time-based to heat foods. The problem is that we can not heat up at the ideal temperature.In this project I insert the microwave temperature sensor that sends a signal to the cell phone.In the cell phone we can insert the desired temperature and turn the device on remotely.Then wait for him to work for you.https://youtu.be/wLLNEIefz8M
Microwave automatic
