In the past few years, depth cameras such as the XBOX Kinect and Intel Realsense have become incredibly cheap and accessible to a huge audience of consumers and makers. Hackers have seized this opportunity and used them to enable an amazing array of projects including 3D scanners, motion trackers, and autonomous robots. However, very few projects have explored the potential of these cameras to augment human perception.
We sought to use a depth camera to assist the visually impaired in navigating and perceiving their environments, and give them a new level of freedom of movement through both familiar and unfamiliar environments. The human brain has an amazing ability to adapt and make up for deficits in sensing by heightening other senses. With this in mind, we asked ourselves: if we can see through our eyes, why not our ears?
Humans also have an impressive ability to localize the vertical and horizontal location and distance of sound while simultaneously distinguishing multiple different sound sources. Vertical and horizontal localization coupled with distance are all that you really need to visually navigate your environment; color and brightness are secondary. If we could take the 3D data from a depth camera and translate it into audio while preserving detail, we could give the visually impaired a tool that would let them fearlessly navigate novel environments without the use of a cane or service animal.
