Here it is the new version:
And a short demo video:
Now it is possible use an EPM570T100 too, "configuring" the PCB with eight solder jumpers (see the legend on the bottom side of the PCB, or the schematic).
The capacitors C31 and C35 are required only for the EPM570T100, so if you use an EPM240T100 do not populate them (as in the board shown in the photos, using an EPM240T100).
Because currently I haven't any EPM570, when available I'll make an other board with it.
In the files section I've added the schematic and PCB Gerber files (traces width/clearance is 7mil/7mil).
There are also layout guides to help to assemble components for both the sides of the PCB, with both components reference and value (file PCB_Layout_Guide.zip).
The components list is here.
Just4Fun
