Amplifier: Augmented
A project log for Custom Record Player
Reworking a low-end record player into a classy design.
zachZach • 09/11/2017 at 20:53•0 Comments
The sounds off the turntable needle directly contains a lot of scratchy, high-frequency noise. The output is also too strong for the LM386 amplifier directly. After some tinkering with low-pass filters, I found some appropriate values get a good sound. I brought out the bass a little more than the original record player, and at this point I find the sound more pleasing than original amplifier.
I will publish the circuit schematic along with the PCB.
