The idea of the new Molbed: Flexinol actuators instead of the magnetic actuators.
Activating the coils on Molbed 1.0 posed some problems: the "kickback" of the magnets moving was sometimes strong enough to affect nearby pins, and reducing the power was sometimes not strong enough to activate them.
To avoid this, a flexinol wire can be used; modulating current can be used to shrink its length by approx 0.5%; for each pin, two wires of approx 24mm will be used; they will provide 1mm of movement that is amplified with a lever mechanism.
Most of the parts will be 3D printed, with a high definition resin 3d printer. The pins will be probably metal 3d printed, and the base of each character will still have electonical connections, breadboard friendly.
Madaeon
Looks promising!
Why did you choose 0.5mm dia. wire? The tech data (http://www.dynalloy.com/tech_data_wire.php) says it needs 4A current and produces 3.5kg of pull force, which feels like too much.
