Antenna orientation
09/16/2017 at 08:24 • 0 commentsAfter routing the initial layout I have came across some antenna design related material namely the AN91445 from the Cypress. Section 7.1 covers the YJ-14015 antenna type (MIFA == Meander Inverted-F Antenna).
By seeing this radiation pattern:
The current orientation is not the best (most likely the keyboard is going to be used in front of the receiever).
It's time to update the design.
Miklos Marton
