11Program the Digilent Nexys-2.
With the generated bitstream, you'll want to use Digilent's software to program the Nexys-2 board. For example, on my personal workstation, I use djtgcfg like so:
cd ISE/kestrel-2dx sudo djtgcfg prog -d Nexys2 -i 0 -f NEXYS2.bit
12After the board is programmed, you can reset the computer by pressing BTN0 push-button.
Once reset, your computer should produce a sign-on message on the display. If you have Digilent's SD-card PMod adapter plugged into JD1, and if the ROM firmware is mature enough, it might even let you boot from an inserted card. (I'm not that far yet as I currently type this; however, as that functionality is added, I'll revise these build steps.)
