I found a used rack mount drawer assembly, 3U. Its plenty big, it's metal for durability and the electronics are completely enclosed when the drawer is closed. All the components in the box will be mounted to the piece of medium density fiberboard, MDF, in the bottom of the box. I'm still deciding on final positions of everything before i cut out slots for the igniter leads to exit the enclosure.
