Today I sat down and wrote the CircuitPython driver for the IS31FL3728 chip that I used for this shield. The effect looks as expected:
The code is rather simple too:
class Matrix7x5:
_ROWS = (3, 2, 4, 1, 0)
_COLS = (6, 5, 0, 4, 1, 2, 3)
_word = bytearray(2)
def __init__(self, i2c, address=0x60):
self.i2c = i2c
self.address = address
self.buffer = bytearray(8)
self._config_register = 0
self._effect_register = 0
def _register(self, register, value):
self._word[0] = register
self._word[1] = value
self.i2c.writeto(self.address, self._word)
def fill(self, color=1):
color = 0xff if color else 0x00
for y in range(8):
self.buffer[y] = color
def pixel(self, x, y, color=None):
if not (0 <= x <= 6 and 0 <= y <= 4):
return
x, y = self._COLS[x], self._ROWS[y]
if color is None:
return bool(self.buffer[x] & (0x01 << y))
elif color:
self.buffer[x] |= 0x01 << y
else:
self.buffer[x] &= ~(0x01 << y)
def show(self):
for y, row in enumerate(self.buffer):
self._register(0x01 + y, row)
self._register(0x0c, 0xff)
def brightness(self, value):
if value is None:
value = self._effect_register & 0x0f
if value & 0b1000:
value &= 0b0111
else:
value += 7
return value
elif (0 <= value <= 6):
self._effect_register = (
self._effect_register & ~0x0f | (0b1000 | value) & 0x0f)
elif (7 <= value <= 14):
self._effect_register & ~0x0f | (value - 7) & 0x0f)
else:
raise ValueError("out of range")
self._register(0x0d, self._effect_register)
def active(self, value=None):
if value is None:
return bool(self._config_register & 0x80)
if value:
self._config_register |= 0x80
else:
self._config_register &= ~0x80
self._register(0x00, self._config_register)
deʃhipu
