I have put all the shields I made so far in one repository at https://bitbucket.org/thesheep/trinket/src and also added a license, the usual CC BY-SA. You will need to install Fritzing to open the files and generate gerbers from them.
There also @oshpark links, so that you can order the PCBs from them:
- Trinket TFT
- Trinket PWM (untested)
- Trinket LED (untested)
- Trinket Buttons
deʃhipu
Are these the most up to date versions of all the shields?
Well, no. But these are the most up to date that have been published.
