ADC initialization (main.c):
//ADC ####ADC####ADC####ADC####ADC####ADC####ADC##############################################################
// Pinmux for the selected ADC input pin
MAP_PinTypeADC(PIN_60,PIN_MODE_255);
uiChannel = ADC_CH_3;
// Configure ADC timer which is used to timestamp the ADC data samples
MAP_ADCTimerConfig(ADC_BASE,2^17);
// Enable ADC timer which is used to timestamp the ADC data samples
MAP_ADCTimerEnable(ADC_BASE);
// Enable ADC module
MAP_ADCEnable(ADC_BASE);
// Enable ADC channel
MAP_ADCChannelEnable(ADC_BASE, uiChannel);
Inside the man.c while{ } loop:
//ADC ##########################################################################################################
while(uiIndex < NO_OF_SAMPLES + 4)
if(MAP_ADCFIFOLvlGet(ADC_BASE, uiChannel))//If a sample is ready
ulSample = MAP_ADCFIFORead(ADC_BASE, uiChannel);//Read the sample
pulAdcSamples[uiIndex++] = ulSample;//Load the sample into an array
//MAP_ADCChannelDisable(ADC_BASE, uiChannel);//
uiIndex = 0;
ADCsum = 0;
//UART_PRINT("\n\rVoltage is %f\n\r",(((float)((pulAdcSamples[4+uiIndex] >> 2 ) & 0x0FFF))*1.4)/4096);
ADCsum = ADCsum + pulAdcSamples[uiIndex];
uiIndex++;
ADCsum = ADCsum / (NO_OF_SAMPLES + 4);
UART_PRINT("\n\rVoltage is %f\n\r",((ADCsum >> 2 ) & 0x0FFF)*1.4/4096);
//UART_PRINT("\n\rVoltage is %f\n\r",((pulAdcSamples[4] >> 2 ) & 0x0FFF)*1.4/4096);
UART_PRINT("\n\r");
