IoT Fidget Spinner with Bluetooth Low Energy and POV LED Display
Burst_Cover_GIF_Action_20170815024638.gifFirst prototype assembled - testing the LED displayGraphics Interchange Format - 1.35 MB - 09/09/2017 at 23:22 |
I received the 2nd prototype version boards from the fab:
They have several improvements over the first version:
These improvements give consistent light output from the LEDs, and enable saving power while the beacon in stand-by mode. The first prototype used about 15mA in standby (4mA by each hall-effect sensor, and another 7 mA by the LEDs), causing the CR2032 batteries to last only for a few hours.
I designed a third prototype version of the board to address these issues, and sent it to the fab. meanwhile, I decided to try hacking around the issues by hacking the board:
You can see how I soldered the capacitor directly to the relevant pin of the TPS60150 (green arrow), and also cut the original trace leading to that pin (the one that goes below the capacitor). I also added a pull-down resistor to the Enable pin (red arrow). This was done in order to ensure the charge pump will start in sleep mode. Otherwise, with the pin floating, it would randomly start before the CPU had a change to pull the line low, causing the LEDs to randomly flicker, sometimes drawing so much power that the CPU could not even start correctly.
Finally, after fixing the above issues, the board was running smoothly. I tested it with the following code, that would simply alternate between red and blue colors, depending on the magnetic sensor reading:
// Setup Hall-Effect sensor
pinMode(D5, 'input_pullup');
digitalWrite(D4, 1);
// Setup LEDs
digitalWrite(D8, 1);
// Indicate magnetic field by color
const RED = 0x010000;
const BLUE = 0x000001;
setWatch(e => {
for (let i = 0; i < 10; i++)
spinner.setPixel(i, e.state ? BLUE : RED, 1);
}, D5, true);
This resulted in a very nice pattern:
I am very happy I managed to produce a functional spinner despite the issues with the board, and already looking forward to getting the next revision of the PCB, which should fix the issues.
The PCB design files are available on github: https://github.com/urish/spinduino-js/tree/master/PCB
as well as the Firmware, which is based on Espruino: https://github.com/urish/Espruino/tree/spinduino
