As for now, capture PCB are on their way, and the acrylic frame has been laser-cut and assembled. The goal is to assembly everything and then think about acquiring an FPGA board.
Uses linear CCD and Zynq SoC
I haven't been posting updates for quite some time. Reasons for that are my almost finished master's thesis, production delays for logic board I planned to use and other real life stuff. I have finally received my Snickerdoodle board a few days ago (it was ordered in the first half of January) — so hopefully this summer I'll have time to do something with it.
Lesson learned: double check CAD models downloaded from the Internet. Luckily, this one can be fixed quite easily.
The boards I ordered earlier have arrived and I started populating them.
As for mechanical parts, they were on their way too, but the shipping company managed to lose them. Now I have to wait until Aliexpress buyer protection takes place so I can get a refund and reorder.
While the boards and the mechanic components are being delivered I thought I'd make an overview of the planned FPGA design stuff.
Acrylic frame has been manufactured. A local advertising company had a laser cutter, and they cut the parts at a reasonable price. I had quite a hard time looking for M2 screws and nuts — these turned out to be less common than I thought.
I have finished the design of image sensor PCB. I had to move one of the mounting holes a little bit to fit the flex cable connector and keep the manufacturing process cheap. These boards are now being manufactured by Elecrow.
