Hackaday.io Hackaday.io
Sign up Log in
MIDI Fighter
A MIDI controller with arcade push buttons and 32 RGB LEDs
w4ilunw4ilun
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.6k views
4 comments
3.8k followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 4
View Gallery
3.6k
4
3.8k
42
Team (1)
  • w4ilunw4ilun
Join this project's team
  • Source Files
  • Build Log
  • Original Idea
  • Video: Midi Fighter In Action
completed project
hardware
arduino midi midi fighter MUSIC SK6812 ATMega32u4 atmel avr DJ
Related lists
Audio
Nice audio projects
Look at this
Just good looking projects made on Hackaday
MIDI Controllers
MIDI Controllers
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 09/10/2017 and last updated 4 months ago.
Description
I decided to build my own Midi Fighter, a MIDI controller that uses arcade push buttons and has RGB LEDs for a light show. Powered by an ATmega32u4 and runs on Arduino libraries. Works with GarageBand, Ableton Live, Traktor, etc. Full build log here: https://medium.com/@monkeytypewritr/building-your-own-midi-fighter-406948137f8f
Components
  • 16 × SANWA OBSC 24mm Push Button Clear body with black plunger
  • 32 × SK6812 MINI 3535 RGB LED
  • 1 × ATmega32u4 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Hardware Top/Bottom anodized aluminum mounting plates, M3 machine screws, standoffs
  • 1 × PCB Black soldermask with ENIG finish
Project Logs
Collapse
  • Build Log
    w4ilun • 09/10/2017 at 18:24 • 0 comments
    Build Log
View project log
Log In/Sign up to comment
Sign up with Github
OR
Luke wrote 09/28/2017 at 06:13 • point
I really want to build one of these but I'm not sure about the ATmega32u4, I'm not sure if I have the skill to hand-solder a QFP chip.
w4ilun wrote 09/28/2017 at 07:42 • point
Luke, I have a few extra PCBs with all the SMD pre-soldered, and also the aluminum plates. PM me if you're interested.
Eugene wrote 10/24/2020 at 09:57 • point
I'm interested if you still have them. If not, would you care sharing the Bill of Materials?
Craig Hissett wrote 10/24/2020 at 22:16 • point
Yeah, what Eugene said! :-)
The 2018 Hackaday Prize
The open-source DIY MIDI Controller for DJs.
Project Owner Contributor
Traktorino: DIY MIDI Controller for DJs
gustavo-silveiraGustavo Silveira
Arduino + MIDI library = USB MIDI Controller
jvsalatinojvsalatino
A capacitive MIDI controller.
Redbull Organ
amon-bensonAmon Benson
How do you make a DJ controller? We'll answer that question.
DIY DJ controller built in audio interface
tuekstueks
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MIDI Fighter", please tell us the reason.
Send message
Remove Member
