Fork of the project Nyan Board for make earrings
panel.zipGerbers version panelZip Archive - 1.01 MB - 09/10/2017 at 19:14 |
Hi
I have improved the render of the image, thanks svg2mod configuration, making a better finish in the serigraphy
Alternatively, I made a tutorial on importing vector outlines into KiCad properly: https://hackaday.io/project/7431-the-kicad-central/log/50436-importing-board-outlines-tips-and-tricks
It looks like the SVG import didn't work quite right — all the curves are converted to straight lines. Have you considered using Fritzing for this? It's not good for super-huge complex projects, but for small artsy things like this it is perfect, and since it uses SVG for everything internally, importing it works very well.
