The main purpose of the project is to design and prototype an IR record replay remote controller. The problem which the prototype is going to solve is to provide a flexible way of controlling large number of different devices with a single remote in places like technical museums. In this use case only few buttons are required but with large number of different IR codes.
There are number of 1 in n remote controllers on the market however in most cases n is quite small < 10. For more advanced models with higher n the price is a significant factor.
The main requirements
- low cost solution
- arduino compatible
- low power consumption
- automatic power-off
- power-on with any button press
- lcd
- durability
Components
1×
Nokia 5110 LCD
£1.44
1×
Pololu 3.3V Step-Up Voltage Regulator U1V11F3
£3.55
