There's not much to say other than RPM9001 is up and running! :D
And here you can see it in action:
There's still a huge amount of work to be done, for example this is what the electronics look like right now:
I'm so happy that it's working so good so far :)
Next log should be about the first tests with the milling head and cleaning everything up.
