Software 2.0 (Bechele 3) has been published.
The bechele software is now hosted on github.
The latest version may be downloaded from github using the following link:
https://github.com/bechele/bechele
Alternatively you may download one of the ready prepared image files – THIS IS MY RECOMMENDATION – because installing all the prequisites is still not too easy.
SD Card Image files are available for RaspberryPi 1b, RaspberryPi 3b and OrangePi-PC
All available SD Card images you may find here – also you will find there a tar-gzipped archive of the project:
https://my.hidrive.com/share/pc-obnpvxa
To check the file integrity you may check against the SHA512 checksum files published on the image download page.
Please report whether on Github or via this page if you encounter any problem.
