Crowdfunding campaign has started! There are kits and aluminum/walnut Nixie Taps.
More info: Nixie Tap Crowdsupply page.
Latest PCBs can be ordered directly. To order, visit PCBWay project page.
Device displays time, date, as well as arbitrary information from Internet (temperature, cryptocurrency price, IFTTT...). It also has an IoT button functionality, via a capacitive touch sensor.
Interaction:
- capacitive touch sensor
- WiFi
- serial port
Display:
- 4 digit IN-12B, with dot
- direct drive
Enclosure
- CNC machined wood / aluminium
Design logs:
- Lessons learned, PCB 1.2
- Enclosure design and prototype 1.1
- HV driver considerations
- Nixie considerations
- Firmware considerations
- Piezo sensor considerations
Most recent PCB:
| current version | status | |
| PCB | B | tested |
| enclosure | 1.2 | tested |
| code | 0.9 | in progress |
| documentation | 0.9 | in progress |
License:
- hardware: CERN Open Hardware Licence 1.2
- software: GNU General Public License v3
mladen
As it can be observed from the video, this interface should be further optimized (skipped detection at 0 and 8). Maybe I need a transistor preamp, since handling this in code is tricky.
Basically, it should
be an interrupt driven program. So, let's dive in:
This prototype illustrated why you should always prototype before production.
Hello! I was wondering whether you have had a chance to publish anything on the HV transformer? I put everything together except the winding of the HV transformer, so any bit of information would be insanely helpful! Thank you so much!
