Hackaday.io Hackaday.io
Sign up Log in
Hackaday UK Unconference FM Radio Rickroll Badge
My Hackaday UK Unconference badge, that plays a chiptune version of Rick Astley's hit on FM radio
jenny-listJenny List
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
590 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
160
2
590
8
Team (1)
  • jenny-listJenny List
Join this project's team
ongoing project
badge radio fm radio Hackaday Unconference
Related lists
UK Unconference Talks
A collection of talks presented at the 2017 Hackaday UK Unconference
This project was created on 09/18/2017 and last updated 8 years ago.
Description
I had limited time to create an Unconference badge. I came up with this, a Raspberry Pi serving as MP3 player feeding a super-low-power FM TX module. Power for the Pi came from a phone booster pack.
The joke was that it broadcast a chiptune Rickroll, thans to my friend [Matt "Gasman" Westcott].
The unusual bit is the antenna, it's a fractal design to pack an FM-radio broadcast antenna into the small space of a badge. It's made from fence wire, with the top of a pin from a British mains plug as its connector. No rocket science, just take a 1/4 wavelength and a pair of pliers, bend the wire into 4, then bend every straight edge into 4, and keep on doing so until your pliers no longer fit the edges.
Project Logs
Collapse
  • Pi config, a bit still to come.
    Jenny List • 09/18/2017 at 23:50 • 0 comments
    Adding an audio output to a Pi Zero: https://learn.adafruit.com/introducing-the-raspberry-pi-zero/audio-outputsOtherwise, there are a few more details to come on Raspberry Pi audio, but all the info on starting a command line audio player on loop at startup is very easy to find by Google.
View project log
Log In/Sign up to comment
Sign up with Github
OR
davedarko wrote 09/19/2017 at 09:08 • point
Nice antenna!
Simon Merrett wrote 09/19/2017 at 17:31 • point
Yep, that's a great antenna (visually at least!).
An add-on to give your Raspberry Pi Zero NFC and stereo audio super powers!
Project Owner Contributor
Raspberry Pi Zero NFC/Audio Skirt
circuitmonsterCircuitMonster
"Allows for the safe and orderly shutdown of a Raspberry Pi and any attached hardware"
UPS HAT For Raspberry Pi - SB Components
undefined
Using the Pi Zero to play HD audio in a car!
Raspberry Pi Car Audio Player
wesley-archerWesley Archer
newest edition of its Power over Ethernet (PoE) HAT. The Raspberry Pi PoE+ HAT outperforms its predecessor by adopting the 802.11at PoE+...
The Raspberry Pi PoE+ HAT Has Been Announced.
undefined
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Hackaday UK Unconference FM Radio Rickroll Badge", please tell us the reason.
Send message
Remove Member
