Y1 - 16MHz Crystal with build in capacitors (the same like on Arduino Pro Mini), SparkFun-FreqCtrl.lbr
Y2 - Super tiny 32.768 kHz crystal, Crystal-ABS05-32.768KHZ-9-T.lbr
0402 package size for all resistor and capacitors
A project log for Bionic Yourself V2.0
Project Bionic Yourself (B10N1C) is a small implant for your arm that makes you a bionic-superhero.
