Preliminary specifications for the new design (subject to change):
1) 12-bit word size
2) single accumulator
3) will have carry bit (register)
4) 4K words of RAM
5) paged & indirect memory access
6) 4 "indirect" registers
7) RS-232 I/O @ 150, 300, 1200, 2400, 4800, 9600, 19200, 38400 bps
8) microcoded
9) up to 4K micro instructions
10) 24-bit micro instruction word size
11) real front panel w/switched & lights (LEDs)
12) 5V only operation
13) target system clock speed: 5MHz
14) implemented w/mostly 74F series logic (because that's what's most easily available)
(1), (2) & (8) are required for it to remain STUPID. The control logic doesn't care about word size, so it could just as easily be a 16, 18 or 32-bit CPU.
Most of the rest of the features listed above are to eliminate the limitations in the original design (see Overview video).
