WM-100-Duino
Arduino IEEE-802.15.4 board.
0 followers
The WM-100-Duino board have an ATMEGA256RFR2 with IEEE 802.15.4 2.4 GHz embedded radio and was designed to have 2 antennas for diversity with a 24dBm PA/LNA. The board have a I2C network with MPL115A2 altimeter, a VCNL4010 luminous sensor, CC2D33S humidity sensor and ATSHA104 criptographic accelerator.
The WM-100-DUINO has the same Arduino-UNO pin out. The main diference is the power source extended from +0.9 to +6.5V. It can works with a single AA battery up to 3 AA. The wireless communication can be used with 3 different communication stacks: LwMesh, IEEE-802.15.4 e ZigbeePro, but only LwMesh was the only released.
With this board is possible to have true IoT MESH device with full open source code directly into Arduino IDE with 5 demos:
- SimpleRemote: Blink a LED remotely
- PeerToPeer: UART by wireless
- EDemo: Energy Scan
- WSNDemo: Wireless Sensor Network
- Sniffer: IEEE 802.15.4 sniffer directly into Wireshark
Cop-USB-USART-avr.hex
Co-processor USB <-> USART bridge. MD5: 7e425433a85e37b68372ab7eefbce53a
hex - 49.83 kB - 09/26/2017 at 02:58
Download
xmega_small_PORTC2.hex
DFU bootloader for xmega32a4 with pin PORTC.2 check. To enter press DFU button before plugging at USB port. MD5: 04de9921521fb853b616f9aa0451beae
hex - 10.88 kB - 09/25/2017 at 22:07
Download
WM-100-DUINO-BOM.xlsx
sheet - 13.94 kB - 09/24/2017 at 15:36
Download
WM-100-DUINO-v1.0-gerbers.rar
RAR Archive - 542.84 kB - 09/24/2017 at 15:34
Download
WM-100-DUINO-v1.0.pdf
Schematic including 3D view.
application/pdf - 1.09 MB - 09/24/2017 at 16:22
Preview
Rich text editor
