2$ pcbs and gerber merging
A project log for Smart car radio
I reversed engineered the canbus screen in my Clio and created a bluetooth remote control to listen to webradios without touching my phone.
manuManu • 10/18/2017 at 21:29•0 Comments
I'm evaluating the jlcpcb.com service. It's basically free : 2$ for 5 pcbs (100x100mm max). As I have 2 boards, the first one should be 2$ (for 5 pieces), but the 2nd one is 5$ (for 5 pieces). It isn't that much but the 2 boards combined are less than the 100x100mm authorized surface. I also wanted to try the GerberPanelizer.exe software discussed on the hackaday blog: https://hackaday.com/2017/06/21/panelizing-boards-the-easy-way/)
So I took the gerbers from EasyEDA from the can and the remote boards and merged them on a single 100x100mm pcb. Here is the resulting image with 2 canbus and 2 remote control boards panelized:
Here are 10 canbus and 10 remote control pcbs for 2$...
