Additional Images
A project log for 1-D Laser-Ring Gyroscope
A 1-dimensional, laser gyroscope...on a pizza pan.
sky-carterSky Carter • 08/21/2014 at 00:22•0 Comments
Figure 2 (Skyhunt): The Completed Ring-Laser Gyro. ^
Figure 3 (Skyhunt): The Oscilloscope Results. ^
Block Diagram (Skyhunt)
Laser Circuit (Skyhunt)
This circuit uses a current limiting resistor to lower the voltage more
suitable for the diode. The diode outputs ≈ 1mW @ 1300nm.
PIN Diode Circuit (Skyhunt)
This circuit uses a gain of 11 and a manual null adjust to zero out the output. This circuit is known as a "common mode rejection amplifier", which is used to reduce noise on the output. The Ouput could be displayed by either a Multimeter or an Oscilloscope.
